How long does it sit before cold starts? What type of oil are you using? What is your oil pressure when hot? (I know it is not a real oil gauge as it only gets pressures in a range from the ecu and does not vary with the real pressure) You might be able to get the real oil pressure with an obdII checker from the ECU. May not be a problem. My 2002 does that if it sits a long time. Cams and tappets with real problems noise would be present at all times if they make noise (noise not required for defects in bearings). Normal for tappets to pump up and bleed down. The cold start noise is while the hydraulic tappets pump up to length and close the clearance gaps.
Name Bertie is great. Mine is named Bessie for the Queen.
Carey
Carey
