My experience with fine wire technology plugs (platinum, iridium) has been contrary to what Brian and Bentleyboy have posted. If you are having any issue with normal plugs fouling I suggest you try them. My personal experience with one of my cars sold me on them years ago. I have owned a 1959 Berkeley since 1974. It has a 2 stroke engine that runs with a 20:1 oil mix in the fuel. For the first several years I owned it every time I started it a plug would foul. When platinum plugs came on the market in the 80's I tried them, and the difference was like night and day. I have never fouled a plug in it since then, and I did not change the heat range of the plugs either. Pretty well had the same experience with an XJ12 that used to be my daily driver, it was difficult to start and would sometimes foul a plug on a cold start. As soon as I put platinums in it those problems vanished. From what I understand of them, the use of iridium allows the electrode to run hotter without damage, which burns off any carbon that does deposit on them. Also, it requires less energy for a spark to arc from a fine wire, so you can run with a larger gap. This results in a larger spark that ignites the fuel/air mixture better. I tend to be very skeptical of manufacturers claims, but personal experience has convinced me that fine wire plugs are worth the extra cost. I have iridiums in my Shadow, and I noticed a positive difference in both starting and running after I installed them. I personally don't care which plugs you use in your car, but you might find them to be a better choice. As their life is up to ten times that of regular plugs, in the long run they can be better value for the money.
