Hi all, me again with another - almost daily - question.
I have all the waistline trim off the car apart from the door handles.
The manual states:
The domed nut is easily accessible.
But do I really have to remove the whole lock assembly?
It seems overkill just to remove the exterior handle which only pushes/presses the push button adjustment screw.
Thanks as always!
The manual states:
Exterior door handle and Actuator lever assembly - To remove
Silver Shadow II, Bentley T2 and Silver Wraith II
1. Remove the door lock (see Door lock and linkage - To remove).
2. Release the Allen screw and domed nut securing the door handle; remove the handle.
3. Release the two bolts, situated beneath the door handle, securing the lock actuator lever assembly to the door; withdraw the lever through the inner door panel.
Thanks as always!
