I have just purchased a '75 SS1, and am new on the forum.
I bought the car as a project, and have put it in for Mot, all is good apart from a problem with the brakes.
When driving, when initially applying the brake pedal the car pulls quite hard to the right(drivers side(UK)), if you keep pushing the brake pedal it levels out fine, it just snatches on initial pushing, the brake pedal does feel a bit harder than it should be before the 'snatching' occurs, all calipers and caliper pistons have been serviced, and appear to move out at the same time, and on the brake balance tester(for the mot) it reads spot on as they apparentley only apply a steady pressure to bring it to a standstill.
Is it something to do with the master cylinder? Any help would be greatly appreciated
