Help please, this car runs and drives but when i go to excelerate it stutters lots and takes forever to get past it all.
points /plugs/condenser/ rotor arm. oil in dash pots all ok. do the carbs need balancing!!!!!! or is it timming any ideas at all. as i can do bits and try.
Gino Italy
Sounds like a classic lack of fuel problem.
Check the pump. It needs to deliver a whole lot more fuel when you push the car (e.g. overtake). Your car probably has the old points driven SU electric pump. I suggest that you check its delivery rate. Try taking off one of the pipes to a carb then directing it into a bottle and switch on the ignition (don't start the car, just ignition). The pump should pump quite a lot of fuel quite quickly. If it doesn't, suspect the pump.
Also check for any filters in the lines that maybe blocked.
Cheers... Rob.
Rob Thanks for your advise i will check the pump next week, I take it its a common problem!.
Can I also ask where i can get the information to set up the points/dwell angles and also the timminbg so i can set it up using my strobe light.
Do you also know the correct procedure to balance the carb's!
I Look forward to hearing from you
Gino
Re: Thanks
Gino
Hello Gino
I do not have carbs or points on my car. Sorry.
The SU pump is a good pump, but it is obviously getting old now. You can replace it or get the parts to re-build yours.
Carb balancing requires a simple air flow tool. try a search for 'carbalancer' on www.ebay.it. You will see the tool I mean.
Most importantly for the other questions you have (and also some help in setting up the carbs), you should check out the Australian Owners club websites technical library http://rroc.org.au/wiki/index.php?title=Technical_Library
Scroll down the page till you see your model. You can get all the technical manuals there in .pdf format.
This document 'Postwar Vehicles - 1946 to 1999 Engine Settings' should be most useful. Look here..
http://rrtechnical.info/enginesettingspost1946.pdf
Hope this helps.
Cheers... Rob.
