Hello
I've just bought myself an 89 Turbo R. I knew the cruise control didn't work, but I'm not even sure the actuator in the engine bay is still present. I expected some sort of vacuum unit to be somewhere around the fuel injection air flow meter, but I just don't see it. Is it vacuum powered anyway?. I also have an unconnected plug attatched to the same lead that goes into the air flow meter. Its a four pin, pins in a line connector. Maybe its part of a loom that isn't used on this car (I know they use standard looms and just use what they need for the appropriate option), but its really obvious just sat there right in the middle of the engine bay. Any ideas?
So does anyone know where the cruise control actuator should be on this car?. Remember also its a right hand drive being in Blitey.
Cheers... Rob.
Cheers... Rob.
