My first post here but I've been lurking for a while.
I have a 1978 Shadow II that I got last summer and am finally catching up on some things I wanted to look at. When I got the car the AC did not work. I looked into that last year and the thermal switch was blown and eventually after some diagnosis thought the expansion valve (I believe that's what it's called) had failed and caused high pressures. That seemed like a spring project so here we are.
I replaced the expansion valve and the drier a few days ago and then today evacuated the system and recharged with R12a (I'm in Canada). The compressor works happily and pressures are good, so that was successful.
Oddly now the issue is that the fans don't seem to blow any air. Before (because the compressor wasn't running) the vents would blow warm air. Now, nothing but a bit from the defroster (in low, auto, or high). Defrost doesn't seem to do anything either. Has anyone experienced this?
I assume one of the handy ACU test boxes could assist, but I don't have one of course. I did see some old posts where someone had built one from the original diagrams - if the diagrams were available I would be happy to go that route and build one!
Thanks in advance,
Brad
Thanks in advance,
Brad
