Hey guys.
Time to fix one more problem in my 1996 Bentley Brookland.
I little confused about the seats in my car
Passenger seat works fine, I can move it up and down, back and forth.
But when I tried to move driver seat it moved passenger side mirror
All other buttons works, I mean driver mirror and passenger mirror.
I didn’t see this problem before, maybe you guys know this problem.
And also ask one more question, my side light and hazard buttons don’t work.
Thank you in advance.
Do you have memory seats? If so, there's an ECU under the seat that controls that. It has a battery that when old leaks and shorts out items on the circuit board producing really wonky results. Worth checking....
Ok, to be honest I tried to remove seats, but it’s not easy, a bolt hold the seat belt buckle, almost no space to remove it, ok, I will try to remove it in my days off
Thank you for information.
So, if I find the leak from battery, I just need to clean the board, what about battery, I can buy it separate?
Often you can clean the board; sometimes the leaked battery will have destroyed it.
Google "Bentley seat ECU battery". You should get lots of hits (it's a very common problem).
Your ECU setas needs restoration, classical issue and symptom.
At least replace battery , hoping it did not leak
Read this
