1 - 1 of 1 Posts
Hello,
In this article, we'll take a detailed look at installing a carbon-ceramic brake system on a Rolls Royce Cullinan.
First of all, the car was raised on a lift, and the wheels were removed from it, the stock brake system was cleaned of brake fluid and removed from the car.
In stock were such components
On the front axle: Steel non-drilled brake disc size 395x36 mm and 4-piston caliper on the front axle
On the rear axle: A non-drilled steel brake disc measuring 398x28 mm is also installed on the rear axle along with a single-piston caliper.
Automotive tire Tread Rim Tire Automotive design
After that, all the necessary parts were prepared for installing the brake system on the car. Details such as
  • Caliper mounting adapters,
  • Brake hoses
  • Mudguards for the brake disc.
Tool Guitar accessory Bumper Automotive exterior Glove
Input device Gadget Wood Electronic device Computer keyboard
We proceeded to burnish the knuckle bearings of the car. And after all the detailing work was done, we were prepared to install the protective shield and caliper mounting adapters on the front and the rear axles.
Front axle protective shields + caliper adapter:
Automotive tire Motor vehicle Bumper Rim Auto part
Rear axle protective shield + caliper adapter:
Automotive tire Helmet Motor vehicle Vehicle brake Automotive lighting
Once all the fasteners were installed and the bolts were marked,
we unpacked the Carbon Ceramic Brake Discs and started installing them on the car.
The top parts from brands such as Brembo SGL and Akebono were used such components are used on cars like Lamborgini Urus, Porsche Cayenne 2018+, Mercedes-Benz, BMW, etc.
The front brake rotors are from a Lamborghini Urus in size 440x40 mm
And the rear brake rotors are 410x32 mm from Porsche Cayenne 2018+
The only custom part is a Brake disc hub part made of titanium.
Tire Automotive tire Motor vehicle Wheel Automotive lighting
Tire Wheel Locking hubs Automotive tire Vehicle brake
All basic checks were performed, and everything was within acceptable limits, our next step will be the installation of calipers and parking brake calipers. As well as checking the end runout of the disc. A separate article will be made on the further course of the installation since the caliper requires special attention.
Thank you for your interest.
If you have any questions or suggestions, please leave comments, I will answer everything if possible.
1 - 1 of 1 Posts
