Hello all,
Any techniques to remove this part, greatly appreciated. Motor mount replacement, passenger side. Having difficulties removing accessing bolt above the throttle linkage.
Thank you!
Replacing the front or both rear motor mounts do not require removal of any part of the throttle linkage. If in doubt, refer to the workshop manual.
Remove the nut, washer, and rubber bush that is on the bottom of the engine damper that your screwdriver is pointed at. Then remove the bolt to the right fastening the damper bracket to the motor mount bracket. Remove the damper bracket and that will give you access to the upper bolt holding the engine mount bracket to the subframe. Like Rob says no need to touch any of the throttle linkage.
