I have a 1993 Brooklands - the rear end "bounces" severly going down the road - it appears that there are no leaks :?: Any thoughts as to what to look for.
Also, vehicle will not start on ocassion, when this happens it sounds as if the timing has jumped way out initially as it starts to crank then it cranks normally -- but - will not start - then if you let it sit and try it several times it will start right up - when it does the initial cranking sounds normal. Is there an advance mechanisim in place upon cranking I should look for that is malfunctioning :?:
Any and all help is appreciated - Thanks!
