Recently it’s become impossible to open my drivers door using the remote central locking. Opening it with a key works fine, but the central locking only gets it halfway up!
Any ideas on where to try first? I had the door card off today and lubricated everything I could see but it’s not made it better.
Rear passenger door latch VERY stiff. Do I need to remove door panels to lubricate?
Driver side rear will not open. Do I need to remove rear seats to remove paneling to get at door?
Are both the inner and outer handles stiff on one, and does the other door not open with either the inside or outside handles? Are the lock plungers moving up when you push the door lock unlock switch?
Rear passenger - only outer is stiff. Lock plungers on all are stiff. Move up and down but usually not full stroke. Rear driver outside used to work till I pushed 2 switches on the door latch area. Now nothing works with plunger up or down. Thanks for the reply. Bob
