I’d like to replace my (missing) purge line restrictor but they aren’t readily available so I’m hoping to make one.
page k45 in the workshop manual says it should limit flow to 1 cubic foot per minute -can someone look at theirs and tell me how big an opening that is?
What year, there were many variations model yr to yr and market 2 market. etc. Pic?
Hi Wood, my 76 is LRE 23114, close. Try Kelly at British Tool for the restrictor. The input hose has a "joiner tube" that connects to it, not sure if you need it.
Do you need the location to mount it?
No, I’ve got the filter in place, with the stub of vac hose on it. I just tried putting a vacuum cap down the bigger hose, drilled a small hole in the end of the cap, and attached a hose to that mess at one end and the other end to the vac port on the manifold. Seems to not affect idle and smells less like fuel. Maybe that will work
