Good morning: I have refitted the propeller shaft to the rebuilt transmission - all is good. I just need confirmation that the Rubber Flexible Coupling (#4 on image below) rests and ROTATES directly on top of the Removable Centre Body Crossmember (#2 on second image below)
Font Auto part Art Fashion accessory Drawing
Map Rectangle Font Parallel Schematic
"rests and rotates" If that were the case you would certainly notice wear on the crossmember and coupling. If it indeed rubs, you have installed something the wrong way. The driveshaft should rotate without touching anything.
Discussion Starter · #3 · (Edited by Moderator)
I have new motor mounts coming as the originals are completely torn and shot. I hope this raises the assembly enough to lift the rubber off the crossmember. I disassembled and reassembled exactly as it was. Thank you for your assistance Wraithman. Greatly appreciated
