1 - 20 of 37 Posts
i have an 1989 Bentley turbo r all my power windows just stopped working, have an so called shop manual ,but does nothing for me . anyone know where power window relay is or where they get power ,checked all fuses that i could find, manual says maybe some by steering wheel but can't get panel down (left hand drive)
on my silver spur there is some screws and it will drop ,but looks like Bentley did something else
Hi Catman
see relay 19 , this relay(see pic att) supplies the ground/earth for all the windows, should click when ign turned on ok
thanks Mike, will try and find it, wish the shop manual was a little better, i work on Jaguars and the British never were any good on wiring dia
Discussion Starter #14
found the screws (only two) second relay doesn't click , took one out of the rolls and still doesn't click , course it may be bad too ,raining so can't pull another for now
Try linking it out like in the picture inset of relay 30, making sure that you have the correct relay, they are usually labelled ok
Discussion Starter #16
trying to download diagrams , but checked for power at relays window lift dead , window latch power on 87
Hi Here is a link for the Electric Windows of your car http://rrtechnical.info/sz/30000/electrical/20.pdf i am a electrical engineer, with 2 RR, Spirit & Shadow, I have just finished installing a wiring loom in the spirit, give me a shout if you get stuck,
There are a couple of fuses for you to check, fuses normally blow before Relays thats what they designed for, check them first
1 - 20 of 37 Posts
