1 - 14 of 14 Posts
Hi
I need parts UR 23318 2 pieces .... Does anyone have a good source: ?? Thanks !
I don't have my parts numbers memorized, and when I hear crossmember I instantly think of the rear final drive crossmember.
Are you talking top parts, as in bows, or something else. A bit more description would help, as a "naked part number" doesn't ring bells in many instances (though it's absolutely great to have, and something not often provided).
Those are the rear swing arm bushings that have to be pressed in. Has the swingarm been removed?
Keep a detailed diagram of the bolts and their direction, the Bellville washer locations, etc. The horizontal compliance bushings will have to be removed and they have lateral shims and an absolute PIA to compress to re-install. You have to use the factory method to compress the compliance bushings.
Try Alber's in Zionsville, IN another good source.
Is the bushing shot or the bolt hole sloppy?
Problem solved thanks all
Would you mind sharing how, exactly? This is useful information for others who may face this same issue in the near future.
1 - 14 of 14 Posts
