1 - 12 of 12 Posts
Hi can anyone tell me the wiring colours or colour of the plug on there oil pressure gauge
my car is a 92 Eight but I want to change the outside temp gauge for oil pressure the wiring is there but the wiring plugs/ colours would really help.
I’ve looked at the manual and can see the wiring light wiring but not the gauges
thanks
Oil pressure gauge:
Black-Yellow to the ground (but via instrument cluster)
Green to the +12V (from ignition F2/A7 fuse)
Purple to the instrument cluster.
Plug is probably blue. At least in 1990 model.
Anyway, I'm not sure, that in Eight there is pre-mounted oil pressure circuit :?
Discussion Starter · #3 · (Edited)
Hi thanks for your fast reply.
so I take it the gauge gets its feed from the sensor via the instrument cluster ??
hi I also not sure it’s pre wired but my Eight has the same gauge sender/ warning light sender fitted as per the R (confirmed Via flying spares) and all wiring terminals are used so gonna take the roll top off and see if I get lucky now I know what I’m looking for.
if luckily ill extend the wiring to fit where outside temp gauge sits.
if unlucky I now know whereto take my feeds from. 👍
Yes. it is due to:
/a/ in older cars, there is pressure gauge in RR's four-in-one instrument,
/b/ in newer cars, DIP can display "oil pressure" warning.
The sender is connected to the instrument cluster through white "old" connector with green-light green wire.
(y)
Hi I have picked up oil gauge Part number UD 71185. Can someone please tell me if the connection under the bulb is the live one or sender connection
thanks.
Ok for anyone interested on my Eight {92}. There are the pre wired plugs on the loom for the oil pressure gauge and the battery volt meter.
They were just taped up next to the main loom.
Discussion Starter · #7 ·
Hi would it be possible for someone to have a look at there oil pressure sender and tell me how the 3 wires are connected-I have 2 greens {one lighter } and a red/white chaser wire but only 2 terminals but the connectors were brittle and the wires came off and I can’t remember if the 2 greens were connected together on one terminal or if a green and red/white were connected together
Discussion Starter · #9 ·
Thank you. -but in true Bentley style why on earth would I have a gauge light wire at the sender !!!!
1 - 12 of 12 Posts
