Good morning @Jim Walters
... I made some new discoveries today.. I went throught the wiring diagram and checked my three relays at the firewall.. As you said the new Bosch relay is number 1 here. the fan and compressor relay.
What is interesting is that on W2 where the loose wire actually belongs is a solid pink wire!..
relay 2 is similar.
and on the servo isolation relay instead of the pink wire on C3 I have a white wire with a black marking.. ?.. I cannot see any WB wire at all involved on the wiring diagram ??
So when I wired my relays like they are supposed to and I turn on the battery the relay starts humming loud!.. and the fans start to move immediately, without the ignithion on run!. without any key!... when I turn the Ignition to run the fans stop but relay hums..
good thing is.. with the pink wire at the servo relay the servos move when I turn the wheel.. only one side works tho!.. when I change the modules from left to right its the other wheel. so I see that one module is broken.
Do you have an idea on what that WB white/black wire is ?.. and obvieously something with the ignition impulse on brown/blue is not correct.
relay 2 is similar.
