1 - 12 of 12 Posts
Hi everybody,
Bought unseen through an auction site, a nice "20.000" series Corniche just landed in my garage.
Issues :
  • ANTILOCK warning light stays on (found one blown fuse, no luck with a new fuse) ;
  • direction indicators do not work, although hazard lights work (fuses are OK).
Any suggestions ?
Any chance to switch outside air temperature from °F to °C ?
substitute a new flasher relay or test your old one. They are thermal design flashers.
Thank you for your help.
I’ve been working on the indicator issue : problem seems located within the hazard warning switch.
Switched 12V never reaches the flasher relay.
I’ll check for an "over-voltage protection" tripping the ABS system. (Car might have been jump started upon arrival in Europe ?? )
No overvoltage relay with fuse like on Mercedes.
ABS, it could be a sensor.
Start be cleaning each of them, front and rear.
Discussion Starter · #7 ·
Indicators issue was with the hazard warning switch.
A good dose of contact cleaner solved the problem.
I guess the ANTILOCK warning light is a similar issue : will be addressed later.
I just removed the bulb to go through the technical inspection (required before registering the car in our country).
Two issues remaining :
  • no park brake warning light (bulb is OK when starting engine) ;
  • unable to understand how to activate rear fog lights (supplied driver's manual is not correct with the VIN).
park brake light : contact cleaner spray on switch
rear fog if original : you may have a separate black switch in the area under steering wheel, left or right
That’s a beautiful car. Thanks for sharing the picture.
Hi everybody,
Issues :
Any suggestions ?
Hello, beautiful car my friend. Im looking to buy one too. What auction did you purchase it? And not to be too forward, what did you pay for it? Smile 😃 Steven
1 - 12 of 12 Posts
