1 - 8 of 8 Posts
Hello
I need to replace the battery earth cable which runs from the negative terminal post on the battery to the body of the car
Does anyone know the correct thickness and ampage for the cable
Thanks Alex
Hi Alec, I would go to the next larger size. Think of cable like pipes and flow of electrons. Even though it's the neg leg, most of the draw will be thru the positive side, upgrading the neg side will not hurt.
I used 2/0 for my car amps power distribution blocks.
Thanks again
Just found another conversion site I believe your 2/0 gauge is 35mm2 about 7mm diameter
Or
1/0 gauge 42mm2 about 7.4 diameter
Will search for 35mm2 cable which I believe is 240 amp rating
Thank you kindly
Alec
This is also a great time to fit an isolator switch, if one is not already fitted. Whenever I put my Rolls in the garage I flick the power off - great insurance against fires on a car with 45 year old wiring.
Hello Geoff
Mine hasn't got a kill switch I normally undo the butterfly bolt on the battery earth cable at night
I will look into the ideal of an isolator switch good ideal
Thanks Alec
1 - 8 of 8 Posts
