I am in the process of restoring my 1973 Silver Shadow SRH15562
We picked this fault up when the heater /a.c blower switch started working intermittently. This worked on just moving the ignition key. At the same time the gear selector lever would not shift from Reverse to drive but would do so by wiggling the key a little. My question is would this fault be rectified by replacing the key lock or do I need to replace the microswitch for the gearbox actuator.
Many thanks
I would probably start by the switch box, which has probably oxydation inside.
If you open the switch box, carrefull, its like opening a watch :
Have a contact spray to clean
