1 - 12 of 12 Posts
Premium Member
Hi Ali, this is a Ghost. In order to get into the service menu via the instrument cluster you will need to have the key on engine off. Once the display of mileage is present, you press & hold the black button. The mileage will then go to zero & come back. Keep holding then you will see all rest able service. Press & hold on each one & wait for loading bar to complete to rest. You can toggle through by using quick presses once in the service menu.
Discussion Starter · #9 ·
Thanks for your help!. The picture is just to show my garage, an older picture actually. We have currently a Flying Spur W12s, a 2021 RR EWB Ghost as well as a Lincoln Navigator and a Ferrari 812 Superfast. We do mostly our own work. Even a "covered" free oil change is just easier to do by owrselves. It takes 20 minutes on the Ghost.
Still, I need to know how to reset the oil monitor on the Flying Spur. The older method of turing on the ignition with the trip button pushed in does not work.
Thanks,
Ali
1 - 12 of 12 Posts
