Hello
Could you please advise. I need to replace this gasket - please see picture below.
Am I right that I should unscrew mirror from the inner frame of door?
So the qestion is what should I do to remove this piese? please see picture below
First pry off the cover for the tiny speaker to give you access to the screw securing the black plastic triangular trim. Remove this and pull the trim back. Now you should have access to the screws securing the mirror. You will not have access to the mirror connector without removing the whole door panel, which is a lot of work. I suggest you loosen the screws enough to remove the old gasket then stretch the new gasket over the mirror if possible and install it.
