Hi - when driving over bumps I can hear some knocking noise from the rear suspension
pls look @ the video - here I am activating the the high suspension hydr arm manually
see movie- link below
Silver Shadow
The knock may be traced to several areas. It can be caused by ram issues. bushings, spring related etc.
I would suggest having a helper search for the knock during test, providing you know what to look for. Metal on metal knock has a way of traveling and narrowing down should not be complicated.
The purpose of rear leveling is to help keep the output shafts level as much as possible.
If the knock appears over bumps, the torsion rods for the boot lid have been known to rattle in the trunk as well as a loose jack..
