The recess, you can carve with a drill bit, faces the bezel and hence the flat side is against the body. After mounting, check for equal clearance between the bezel and bulb. Ahh perfection.
Also, the top hanging pegs can be adjusted and many are clogged. You want a little tension on the bezel to keep it from popping off.
