Second SZ-series Silver Spur I have owned and second one I fixed the remote gas door by spraying WD40 directly into the solenoid at the fuel filler area. Fixed both cars. Both has the same problem. I have seen people trying all kinds of other stuff to fit it but thought I would share that from two of them I owned.
Even a better penetrating oil is Tri-Flow.
WD-40 just evaporates after a while.
The point is no wiring issue, fuses, or solenoid replacements needed. Simple spray solved the problem. This issue has come up on this board before and I don’t recall this being a suggested solution.
