My 1990 RR silver spur ll has problem with fuel pump system . The fuse marked ENGINE MANAGEMENT B9 is literally burning up 25amp fuses. Previous owner ( a bit suspect ! ) said he replaced the fuel pump with a USED UNIT ! .
1/ MY CAR NOW HAS TWO PUMPS , is that right ? For a non turbo car......
2/ here is the vin #
SCAZN02D9LCX33196
3/ CAN ANYONE PLEASE TELL ME WHAT ELECTRIC FUEL PUMP SYSTEM THIS CAR CAME WITH AND IS SUPPOSE TO HAVE ?
4/ LOOKING AT PICTURES, IT HAS THE DUAL ELECTRIC PUMPS , side by side with the small Accumulator underneath them ...... which looks to me like a TURBO SET UP ?
5/ IS IT POSSIBLE THAT THE DUAL PUMPS ARE PULLING TO MANY AMPS ?
6/ OR PERHAPS ONE IS BAD AND CAUSING THE PROBLEM .
7/ I HAVE AN , IN THE FUSE HOLDER AMP TESTER, WITH THE CAR RUNNING THE FUSE IS PEAKING AT 25 TO 28 AMPS ! SEEMS VERY HIGH .
8/ THANK YOU ALL IN ADVANCE
UNCLE STEVE
