Hi! sorry if this seems amateur, but I need to change my fuel accumulator on my 1984 Silver Spur, Any Advice, do I just remove the fuel pump then change it, are there any steps to do before hand?? Thanks!!
Hi there. Did you ever figure out how to do this? Am about to do the same on my 1988 Silver Spur and am looking fro some guidance from someone who's done it.
There is nothing tricky here. Simply undo the fittings and replace. The fuel accumulator will most likely be a Bosch with a number printed on it. A lower cost replacement will probably be found thru Bosch or Mercedes parts houses.
