My 76 Shadow has been running better than ever over the last two months. I got the carbs and idle tuned to perfection; running at perfect 600 RPMs when sitting at an intersection light.
Over the weekend, however, the automatic choke, which characteristically only requires a small tap on the gas pedal to turn off after a few moments of warming up, did not kick down to the normal 600 RPM speed. It’s stuck on fast idle at about 900-1,000 RPMs while in gear.
This issue popped up overnight. Nothing had been touched. No warnings or uncharacteristic behaviors.
I try adjusting the “idle stop screw” and nothing improved. I then remove this idle screw altogether, thinking the car would stall, and still no effect. I lubricated all the throttle controls to eliminate any sticking, but this did nothing.
I do not see much posted about this problem, so I am not sure how common this issue is.
I’d appreciate any first-place-to-start recommendations.
Thanks!
Thanks!
