Hi.
The battery is very healthy and lights are bright (including when TRYING to crank)
The Park/Neutral interlock is working well - when in anything other than N or P, the key results in nothing happening. When they shift is in P or N then a loud "click" can be heard from the relay panel under the glovebox - but not a sausage from the starter.
Oddly, when I removed the relay labelled "starter interlock" - another relay STILL clicked when the key was turned to the start position. Is there more than one relay?
I know it might be the starter solenoid has died, but as I have no jack / lifts etc, I wondered if there were other things to prod and check before trying to see if the starter solenoid is being given a signal.
Certainly something is happening as far as a relay in the area under the glovebox - but looking at my manual on CD there seem to be a lot of additional interlocks, fuses and relays - alas the quality is so grim it is almost impossible to see what is what - so not really quite sure where to go testing. I have meter and good old lamp and wire - just no idea what relays etc I should be looking for.
All thoughts welcome, my last ditch attempt I guess is to try and connect directly to the start solenoid and as a "get me going" device, just have a button somewhere I can prod to start the old girl up.
blue skies
Mark
blue skies
Mark
