Hi folks,
Selling the 1970 engine (plate on firewall says 410ci), transmission (a GM TH400) with remote servo shifter, and all engine accessories still mounted. The subframe and suspension are not for sale. I drove the car with this engine before removing it myself. Same engine and 30k (130k) miles on the odometer as when it sold at Barret-Jackson. The previous mechanic said 3 cylinders were low on compression. I don't know how low. It ran ok when I drove it a few miles before replacing it. I didn't drive it hard. It's been stored inside since removal. I'm hoping someone else sees value in its history and would enjoy it. The engine wiring harness was snipped-off where it's bundle exited to the passenger side fender. While it's a bit oily, it has not dripped while being stored. Parts not pictured are also available: Differential+Cross member, half shafts, prop-shaft(LWB), steering parts, wheel hubs, brakes(were dragging), wheels with tires (5). AC unit from the trunk, Radiator, reservoirs, spare tire support, stock front upper coil spring mounts, etc. Please ask if interested in other parts.
At the time of this posting, you can view the engine & transmission eBay ad here: Johnny Cash's Rolls-Royce Engine, Trans & accessories | eBay
