Hi, can I use semi synthtic oil in my 1980 shadow11 or what is best any advise would be appreciated
Oil
I use semi-synthetic oil for my Shadow as advised by RR-owners in The Netherlands (with some additive friction fighter). Works fine :) .
:arrow:
I'd be more concerned about ZDDP content than synthetic vs. dino. A lot of the newer formulations have much less ZDDP in them (as it degrades catalytic converters).
Jeff.
Agree with Jeff, ZDDP has been on the decline. Try Redline oils as they have 'normal to a bit high' ZDDP as Mobil 1 took away much ZDDP a few years back. Have lab tests confirming this, which the lack of enough ZDDP was causing problem on my tracked '85 Ferrari.
Just read that last line in Steven's note.
I use Mobil 1 in my '79 308GTB with no problems at all. Then again, it sees no track time.
-rick
