getting to much fuel in cylinders the plugs are fowling up with fuelThere is a part number on it, likely Bosch. Buy from German suppliers aka, Mercedes.
And you are sure it's bad?
CD6495SXR electro-hydraulic actuatorWhat is the part reference you are looking for ?
Where are you located ?
yes i did that and run perfect for a while then some problemUnplug it and see if it cures your problem. There's a 2 pin electrical connection on it.
Can you elaborate on the problem?yes i did that and run perfect for a while then some problem
