Hi!
I've started changing my distributor belt, so far I've marked the wires, removed the caps and arms and both dust covers.
In the technical info from the Australian site, it then says to remove "the upper, inner outer circlips" from the group 1 spindle.
I can only see 2, a smaller one on the spindle and a larger one that holds the bearing in place, and I've removed those.
How do I get the spindle out?
Or do I need to remove the distributor assembly from the engine?
Es
Es
