My 78 Shadow was running just fine, then 2 days ago, I went out to start her & nothing..I turned on the key and the oil / gen light did not come on. I turned the key...Nothing..I checked all the fuses, and made sure the gear selector was in park..nothing...I checked the battery and it was dead...some how the polarity was reversed...??? I replaced the battery and cleaned and rechecked all the fuses...still nothing....I figured it must be a bad wire at the ignition/light unit..BTW after the new battery, I still have no headlights, electric windows, or radio....anything that will be activated when the key is turned on...The electric door locks and the clock are working....The only thing that does work at the ignition/ light module, is when you pull the domeswitch out, an overhead light will come on...I am at a loss and I am dead in te water...
my serial# is SRG 34871
Thanks for any help/suggestions Lee Benson
