1 - 7 of 7 Posts
Hello,
Does anyone know where I can find one of these (right side) - are there any other cars that had them?
I need to add one to the passenger side as well (currently only the driver side is fitted).
Thank you.
Sent from my EVA-L19 using Tapatalk
You might want to get together with someone who has the right side mirror already fitted.
On the two series cars the right side mirror is about as useful as a screen door on a submarine if it is mounted as the factory mounted them and on these cars, if you want to have a future resale market for the one(s) you're now the custodian of, you don't want to mount them in a non-standard position.
Yes, I already have the measurements - basically the same is the driver's side (in this case both would be driver's side as this style was only fitted to the "driver's side" - so I will need to find a RHD one).
Hi Bentleyhigh,
Did yo found a solution for your side mirror.
I have the same problem on my shadow RHD driving in Belgium.
I purchased a round mirror assy and i installed it on the left hand side door .
No way, i do not see from my driver position what i need to see to drive the car safely!!!!!!
Wow just caught this thread, I thought it was just me, my SSII right door mirror is all but useless. I figured they put it there for symmetry because in practical use, there is none, no matter how I attempt to adjust it. Other than perhaps symmetry what good is it?
1 - 7 of 7 Posts
