If I'm reading it correctly, I belive the workshop manual suggests removing the cylinder block coolant drain plugs when renewing the coolant (yearly).
However, the parts manual shows a pair of cylinder block core plugs on each side, but doesn't label which are the coolant plugs and which are (I presume) the oil gallery plugs.
Anyone know if the washers for the coolant drain plugs are XB1095 or XB1193?
Thanks,
-- Jeff.
Thanks,
-- Jeff.
