Hello every one,
I was wondering when RR put a catalytic converter on the SS1
I have a 1972 SS1
The car runs great with no load no black smoke from exhaust pipe when you rev. up the engine but puter in drive and hit the throttle it's a dog.
Going down the road at 70 and floor the throttle the trans down shifts the engine seams to rev. up but no more speed it will actually slow down because now I am in 2nd gear. even on take off you better have a clear road it will take awhile for it to get rolling. It's the same eng. hot or cold
New plugs & wires, airfilter, checked dwell and timing it's on the money, cleaned the carb. pistons put new oil in the top. checked vac. hoses
like it's holding back or some thing... have to just about floor board the throttle to get 70 mph. melted the alumimum shield off the front muffler
saturday....
I am lost ????? if it was pumping raw fuel in the exhaust it should burn black when you rev. up the engine right ???
if I was getting fuel starvation in 48 miles I have burned 10 gal of gas so I think I can rule out the pump and filter
Please has anybody had this problem before
Thank you for your time
Glenn,
I have a 1972 SS1
saturday....
Glenn,
