Carpet yardage requirement for Shadow II.
134 Views 1 Reply 2 Participants Last post by  Wraithman
Does anyone know how many metres of the Wilton carpet you would need to retrim the entire car? ie boot, floor and door cards? The carpet is approx 900mm wide I believe. Also the carpet has a 'direction' I believe. Feedback appreciated :)
1 - 2 of 2 Posts
I have never seen a direction on the RR carpeting. You will also need the edge binding which is skivved. You can easily figure out the amount of carpet by measuring length and width for each and figuring out, once the width of the carpet roll is known. The trunk mat is the widest of all sections. The binding can also be measured with string around the edge and the sum total (which is a lot) can be calculated.
1 - 2 of 2 Posts
