1 - 15 of 15 Posts
Continental R started as normal and ran for a approximately 10 mins. without any warning the car shut off and would not start again.
Auto electrician traced the fault to a faulty relay - I think that it controls the fuel pumps and other things. This has been replaced and the car seems to be ok now..... :unsure:
Has anyone else had a problem with this part failing.
I could not get a metal replacement so now have one with a plastic cover - Are the metal ones still available?
I am based in the UK, and would consider swapping out the plastic relay for the original metal look....
I'm in the US but I've been told the old metal ones are no longer available. The plastic Bosch relays are available from multiple sources (in the US from Amazon for about $12.00 [c. 10.00 GBP] each). You can replace ALL of the relays in your car for less than $500. They can be located by consulting the TSD on the Bentley Heritage site. I've replaced all the 30+ year old relays in my SZ cars. The total time to install was about 30 minutes per car. It's so easy and inexpensive it doesn't seem worth being inconvenienced (or worse) by a failure.
Hi do you want the metal one to retain the original look. ??
Im also in the uk and have a few of the metal ones hanging around
Yes, this relay is a classic and should be in glove box.
The metal one with red mark is difficult to find, you should at least by one original inadvance from Blue, or 2 if you are purist and want the metal original one on your car with red mark.
Hi Jean, I did not know that this relay fault was common and it is advisable to have a spare... Thanks for the advice..
Which car/year do you have, because I might advice another essential relay to keep in glove box !
Hi Blazer,
I strongly suggest you have in glove box
  • 1 Engine management relay
  • 1 fuel pump relay
  • 1 switch box coupler UD72522
Hi where on the car can I find these relays.
I’ll go and buy new Bosch ones and change them.
It depends on years, for Blazer they are under the bonnet, under black plastic, right side for LHD
OK, s different from Blazer.
To be checked with your VIN, but engine management relay is defferent before 94 and after.
Fuel pump relay should be the same
Usually, those 2 relays are under the bonnet. If you have black plastic cover there are under, around the shock absorber area.
1 - 15 of 15 Posts
