1 - 7 of 7 Posts
1971 Bentley T
Can anyone tell me how to remove the trim pad at the side of the aircon switch panel, the vertical one to the right of a passenger's knee on a RHD car (or v.v.)? The tech manual is little help, it says to remove it using a wedge-shaped tool, but where should it be levered, top, bottom, sides? I am concerned I might break it by doing the wrong thing. The parts catalogue might be helpful if I could find the part.
Any help, please?
Alan D.
1971 Bentley T
Discussion Starter · #2 ·
Panic over. I've discovered that if the top of the panel is levered out with as much force as one can dare to bring to bear, a corner comes away and the rest can be cammed out easily. It's held in with a few spring clips, and a bit of age. So that's what the manual should say.
Alan D..
1971 Bentley T
Geoff, those pictures are exactly what I wanted to see. I had pried and shoved a wide screwdriver into the gaps but was afraid of damaging the pads. I reasoned it out after a while and realised that probably it hadn't moved for 50 years, and it HAD to come out from the top.
I wanted to remove it to install automatic cabin temperature control when using the cooling system. Look at the Australian forum under "Charge quantities for R134A"
Alan D.
Hi Alan
I've been following your thread on the Australian forum - very useful and interesting.
The charge quantities and other info is useful as I intend to convert my A/C from R12, when it stops blowing cold air - it's ok at the moment so will hopefully be a couple of summers off.
Geoff
The trim pads also tend to stick to adjacent leather surfaces just like the elbow pads on the door cards. Use care with a plastic scraper to gently pry apart. The pad retainer usually develops a bit of corrosion.
Series II cars do not have this setup.
1971 Bentley T
Discussion Starter · #7 ·
Hi Wraithman, I think that someone had used a particular leather dressing that turns gummy after a few years. I've cleaned the panel and applied a Gliptone dressing which seems OK in that respect - I've used it almost everywhere and found no problems. I don't have the energy to do the other fiddly bits. Volunteers?
Alan D.
1 - 7 of 7 Posts
