1 - 8 of 8 Posts
Does anyone know alternate sources/manufacturers for brake pads for the SY series cars?
If so please post part #'s Thanks!
Just for the record, I was once told Jaguar XJ6 front pads were a good substitute for Silver Shadow rear pads, with a little modification. So, I bought a set from Autozone and found the "little modification" entailed cutting the pads down in length and filing (elongating) the holes for the locating pins.
Needless to say my order for SY1 pads went in to Flying Spares the same day.
Ok,thanks. I was hoping to avoid the UK route.
I know official substitute exists in Europe for all Shadow ( both types of front brake discs), and I think they are all made by FERRODO, the "original R-R" and the substitute
What about this ?
http://mutley.hypermart.net/RollsSubstituteParts.html
1981-87, 20,000 series Silver Spirit and Silver Spur parts:
-Transmission: As for Silver Shadow.
-Front Brake Pads: Ferodo FDB1284 complete with sensor hole. The old sensor can be easily transferred over. Mintex MGB633 w/o 5mm hole which can be drilled. (ClassicGarage.com at $9.96 a set of 4) See "General Information" for brand cross reference. PIC:
-Rear Brake Pads: Mintex MGB537, Ferodo FDB-1296-A at $68.79 a set of 4 from: Rock Auto
-Parking Brake Pads: Mintex MGB563 or TRW-GDB563 (ClassicGarage.com at about $90 a set of 4)
You should read this also
http://au.rrforums.net/forum/messages/17001/18612.html?1442674273
The ref from kakaparts seems to be
ROLLS-ROYCE UG99999L
With that reference, here is what I found from there
https://www.oscaro.com/jeu-de-4-plaquettes-de-frein-bendix-571247x-715014-402-p#
BENDIX - 571247X
Montage d'origine de l'étrier de frein : Lucas/Girling/TRW
Quantité : 4
Gamme : Origine
Épaisseur : 15,1 mm
Longueur : 78 mm
Hauteur : 66 mm
Version : X
Ce produit ne comprend pas :
Contacteur d'usure de plaquettes de frein
Autres références du produit :
  • BENDIX : 20491, 571247
Équivalent à ces références constructeurs :
  • AC : GBP216
  • BENTLEY : UG99999L, UG99999R
  • BMW : 88881610637
  • FORD : 1540859, 1591094, 6099237, 1591099, 5026169, 6080699, 1576829, 1554550,....................................................................................................................
Thanks Jean . Let you know what I find.
Pads for front non-vented discs are available from several sources.
1 - 8 of 8 Posts
