brake calipers on a T type are usually pretty rotten.
I have overhauled a lot in my time and usually need new pistons, and seals. The rear calipers have the park brake linkage and often seize. they can usually be freed off ok but can be troublesome.
You can now buy new callipers from Introcar £145 for each front and about £295 for the rears new. Fronts are in stock but rears are on their way.
if it is seals and pistons you need you are looking at about £30 rear and £42 front, for the seal kit and between £15 and £20 per piston, depending on wether it is the early T1 with a master cylinder or the later one without.
Thanks Matt
[email protected]
www.introcar.co.uk
