Bentley Turbo R with BIG Brake’s
Well as you know I have a RT with Big Brakes and the cost of the replacement pads are £390.00
So I went on the hunt for replacements I found that VW LT van pads where the same pad so I got a set of EBC pads had the Discs Faced
The pads where to fat the material on them had to be sanded of to fit don’t forget the shims and they must go in the correct way this is imperative you get Right other wise you will end up with brake squeal
Well I have done 3000 mil with them in and haven’t had a problem
I removed the pads yesterday to have a look and there ok so I decided to put this on hear for others
I haven’t refitted the sensors as I don’t need them as my cars are well checked but the next set I fit I will fit sensors
All so there is less brake dust on the wheel’s compared with originals
