Has anybody got what changes to the wiring have to be done to change from dynamo to alternator and has anybody got measurments for a bracket to mount this i recieved these details about 7 years ago from rrec member but have lost them thanks in advance ......
It depends on what alternator you want to use.
I think we normally take a shadow one and use the shadow mounting brackets. Plus you will need and slotted adjusting bracket.
I have one in the workshop at the moment and will get a picture of it if I have a chance.
Then you will need a regulator. Field and battery +ve are there. May need to add an ignition +ve.
Should be able to get all the parts fairly reasonably used.
just curious.. why are you going to an alternator?
I added AC to my Cloud II and figured I'd have to go with an alternator, but after running AC last summer with the original dynamo, I found the dynamo keeps up fine.
