I recently bought a Bentley 8 . Everything OK apart from noisy front suspension. On examination the top of the shock absorbers seem to be rubbing on suspension arms. This is with both wheels pointing to front. It seems as though they need turning to avoid this contact. If this is so what is the procedure ? There is some knocking noise coming from the front which reduces some time after start up. I assume I have Active Ride as hydraulics and elctric s are connected to each shock absorber. Help would be greatly appreciated.
Also how do you check rear brake pads for wear without dismantling ?
