What is the battery group of the bentayga ? Is it a common battery or something special that can only be obtained from the dealer? Thanks
there is only one battery it is under the floor mat of the passengers seat.
I would be suprised it is a very special battery.
Make a picture or write what is writen on it in amps, then look where is the + ,
Make sure you get exactly the + at the same place, otherwise you may destroy electronic and that could be a disaster
I don't see anything special on this video
just make sure for the +, make a picture before you unplug yours with your phone, and look for eaxctly the same amps, 100 AH or more.
Choose a premium brand battery, as those cars need the highest quality, with AMPS / Hour and AMPS to start, which is 2 duffernet values.
You should get a permanent charger to keep it plugged when you do not use it
