1. Fuel injection pressure regulator seals
Use 2003Audi S8 4.2 V8, Bosch #
1287010001
2. Lower Front Ball Joints = bentley part PD20807PA
Use moog k9919 or Lemforder for Mercedes #LFD1074102 cross
ref.3 1403330327
3. Trunk lift supports - 1998-99 arnage use 12.36 inch can be found on Amazon or eBay for $20 a pair (need 2 pair )
4. Trunk Lift Supports 2000 up use 11.3 inch
Find them on Amazon or eBay for 1999-2004 Jeep Grand Cherokee hood struts part 4048
Cost about $10 a pair (need 2 pair )
5.Front Upper Ball Joints = Bentley part PD20799PC
Use MOOG # K9025 for Volkswagon
6. Transmission Filter up to 2006 model = GM# 8675545 for GM4L80E
transmission
7. Fuel Injector Seals = Bosch used on 2003 Audi S8 4.2L V8
8. Cabin Pollen Filter = Mann CUK2736 or Napa # 9372
9.Steering Rack = Standard Audi Variable , rebuilt cost $600-$900
10. Turbo Chargers = Garrett just match up on website
11.Thermostat for 6.75 engine =
Use an old Cadillac 472 v8 from 1968-1974
12. Serpentine Belt = Contitech 7PK2337 or any 7rib x 92"
13. Upper Control Arm Bushings = Napa# NCP 267-1474 (not exactly the
same - must make a sleeve to reduce inner bolt from 14mm to 12mm ,
These are for a Toyota Tacoma but will
stiffen the front slightly.)
14. Oil Filter = Wix 51231 or Fram PH2995
15. Fuel Filter= Hengst H84WK01 or Fram G-3744 or Mann WK853 or
Knecht KL30 or Purflux EP153
16.Engine Air Filters = K&N # 33-2890 (KAN33-2890) these are reusable
17. Electric Cooling Fan Resistors =
www.mtcparts.com # MTC1856 ref. #
67-32-8-371-873 includes both , easy to swap out located on fan
shroud
(commonly cause Low Fan or High fan DTC ), Cost less than $10
18. Front abs speed sensor PC21080PA -
Use BMW34521182076
19. Rear abs speed sensor PC21081PA-
Use BMW34521182077
