Hello
I have noticed a leak from the body of my front hydraulic pump (behind the thermostat housing). this is not major, but over time, fluid is being lost. It looks like it is the body o-ring seals. According to the manuals, this seems easy enough to fix.
But
It is necessary to release the low pressure inlet and the high pressure outlet pipes. This means that items have to be bled. Does anyone know simply if this means I have to bleed everything (all brakes and suspension), or does this pump only feed some circuits?
I realise that there are pictures in the manuals, but the CD never does them justice, and its really hard to tell what piping goes where on a low res black and white picture.
Also
How do you bleed the system. There seems to be a number of points.
Any info from those who have done it?
Cheers... Rob.
But
Also
Cheers... Rob.
