1 - 2 of 2 Posts
Hello, new member here, looking for assistance! Disappointed to find the previous owner has taped over the air bag section of the driver's info panel! Underneath, the air bag light is on!
Tried to read the codes using instructions in tsd5069pt2. I cannot get the drivers info panel to flash on off. Maybe my 3 second timing is off...
But my 3-way diagnostic flat plug, with the green wire in the centre, has a single wire (also green) connected to it. Do I carry out the switch-to-ground with this single green wire connected?
Thanks in anticipation.
Alan
Yes, the green wire is the one to ground out to clear the light. With DIP programming I've found the exact seconds the manual specifies do not always work, often takes longer.
1 - 2 of 2 Posts
